Wait Time and Calendars
  • 1.  Wait Time and Calendars
    Posted 26 days ago
    Hi All
    Just getting started with manufacturing and trying to decide on some setup stuff
    Does wait time use a calendar? I would think not, for example, paint can dry happily over a weekend or a holiday
  • 2.  RE: Wait Time and Calendars
    Posted 24 days ago
    From my understanding, "Wait Time" is not affected by the Shop Calendar. But the "Shop Calendar" will pause until the "Wait Time" has expired. That secondary clock starts as soon as you do a capacity journal for the line. So when look at the "Allocated Capacity" you will see the "Wait Time" has kicked in and the next operation on the Routing is paused. Play with it in your test environment to get the right mix for your business model.
    Alfredo Zelaya
    Sr. Systems Analyst
    Megadyne Americas LLC
    Fairfield NJ
  • 3.  RE: Wait Time and Calendars
    Posted 24 days ago
    Thanks Alfredo, that was what I was thinking and it seems to work that way
  • 4.  RE: Wait Time and Calendars
    Posted 24 days ago
    Mark - to add to the comments a good use for wait time is with subcontractor operations. An example would be 5 days that you will have to wait before the subcontract work comes back. When you refresh the production order the wait time on the subcontractor route steps is used in the date calculations. Since wait time is in calendar days you can plan the 5 days reasonably well.
    Best Regards
    John Grant
    John Grant
  • 5.  RE: Wait Time and Calendars
    Posted 23 days ago
    Thanks John
