Phil,
Your not the first person asking this question... When you create an Assembly Order the Lines are that of the BOM Items and quantities. So if the line reflect Label with a QTY = 1, the Quantity to Consume = 1. You can add new Item lines, to the Assembly Order, consuming more of the quantity. See my pic below adding the last line.
Make sure you update the Quantity Per to calculate the correct value. In my example, my Item has an original Quantity per of 10 so I only need 1 hence my new line shows Quantity per = .1.
After adding the new line I can produce Warehouse Pick for additional request.
Sent: Mar 04, 2021 12:54 PM
Subject: Assembly Orders - Business Central
Hi
I'm using Assembly orders (with Advanced Warehouse Management) in Business Central to provide basic kitting functionality.
We have a simple bill of materials that consists of three component items that are assembled together to produce an assembled item.
I have a situation where one of the components is damaged and cannot be used.
Is there a way that I can issue an "extra" component to the assemble order so that the full quantity on the original assembly order can be made.
e.g. Assembly order is created for quantity 10. Component items are on a 1-2-1 ratio so 10 of each component item are issued to the assembly order. One of the component items is damaged so I want to be able to issue a further one of that component so I can still assemble a quantity of 10
Phil
Phil Tew
Bionical Emas
