Double-click to open card in lists
  • 1.  Double-click to open card in lists
    Posted Jan 04, 2019 11:08 AM
    ​Is there a way to make the double-click work in non-editable lists, like the posted sales invoices for example?
    In that list, you need to hit "View" because the double-click doesn't work since Edit is grayed out.
    NAVUG Summit - Post
  • 2.  RE: Double-click to open card in lists
    Posted Jan 04, 2019 04:02 PM
    A few other ways I always show my users (not sure if they'll work in your scenario, but it's worth trying):
    • Right-click --> Edit or View
    • Try the ENTER key.
    • Ctrl+Shift+V  /  Ctrl+Shift+E
    Kaukauna WI
    NAVUG Summit - Post
  • 3.  RE: Double-click to open card in lists
    Posted Jan 04, 2019 04:23 PM
    What version of NAV?
    I just did a quick test, double-click does work for me on posted document lists in NAV 2017. But I do remember it being a problem in older RTC versions, just not sure what versions. In those older versions, I think I found if you double-clicked on the record in the "No." column it did work, but on other fields or places in the row, it would not.
    Cynthia Priebe MCP, DCP
    NAVUG Summit - Post
  • 4.  RE: Double-click to open card in lists
    Posted Jan 07, 2019 04:12 AM
    HI,
    Please check that CardPageID property is set in List Page.
    Like for Posted Sales Invoice Page - 143 have cardPageID is set to - Posted Sales Invoice.
    Saurav Dhyani
    Duluth
    NAVUG Summit - Post
  • 5.  RE: Double-click to open card in lists
    Posted Jan 07, 2019 05:35 AM
    We reported this to Microsoft when NAV 2018 was released, still not fixed in BC either. This is a feature of the NAV 2018 or later that adjust the standard button based on security.
    Per Mogensen
    Mergetool.com
    Box Elder SD
    NAVUG Summit - Post
  • 6.  RE: Double-click to open card in lists
    Posted Jan 07, 2019 08:13 AM
    ​Thank you Per, it is indeed for NAV2018.
    NAVUG Summit - Post
