Sort Descending by Default
  • 1.  Sort Descending by Default
    Posted 20 days ago
    We are on BC 14, but we use the desktop client. Is there a way to default a list page to sort descending on the ID?
    Gregory Alford
    Tri Star Metals LLC
    Aurora IL
  • 2.  RE: Sort Descending by Default
    Posted 19 days ago
    Yes. You'll need to change the property of the page under the "SourceTableView" where you can set the sorting of a particular field.
    Example: SourceTableView = SORTING(Cross-Reference No.) order(Descending)
    Kristoffer Ruyeras
    VP of Operations
    Seattle, WA
  • 3.  RE: Sort Descending by Default
    Posted 18 days ago
    Where do I find the "Source Table View"?
    Gregory Alford
    Tri Star Metals LLC
    Aurora IL
  • 4.  RE: Sort Descending by Default
    Posted 15 days ago
    You need to set the property in page as highlighted in attached screenshot.
    Saurav Dhyani
    Upgrade Technical Futurist
    Duluth
  • 5.  RE: Sort Descending by Default
    Posted 15 days ago
    That is what I was aftraid of. We are on full extensions. Therefore, I have to involve a developer. Heavy sigh...
    Gregory Alford
    Tri Star Metals LLC
    Aurora IL
  • 6.  RE: Sort Descending by Default
    Posted 15 days ago
    In that case I would suggest, that you can create a new page based on the same table and set the SourceTableView as per your need.
    ** If you have custom extensions on that page then it may be an issue but if its just for viewing purpose  then you will be good there.
    Saurav Dhyani
    Archerpoint Inc.
    Dehradun, India
    Blog - https://www.sauravdhyani.com/
  • 7.  RE: Sort Descending by Default
    Posted 14 days ago
    Hey Saurav,
    Is that the best way to go about it? - when you have a custom extension and need to change sorting or make other changes, go ahead and create a new page for that specific change instead of disrupting the existing extension.
    ~Meenakshi
    Meenakshi Singh
    Ruby Award Recipient
    NAVUG/D365BC-Community Summit:
    https://www.dynamiccommunities.com/events/community-summit-north-america/
    October 7-9, 2020
