NAV 2017 job queues skipping a day
  • 1.  NAV 2017 job queues skipping a day
    Posted 28 days ago
    Hello everyone,
    We are encountering issues where a couple of our nightly running job queues are skipping a day after previous run unless we manually update the job queue to reflect the correct date.  The priority is the same for all ready job queues and there is nothing set under no. of minutes between runs on either job queue that is encountering the issue.
    Would someone please be able to provide some input on how to resolve this issue?
    Thanks.
    Paul Connolly
    Diesel Forward
    Windsor WI
  • 2.  RE: NAV 2017 job queues skipping a day
    Posted 26 days ago
    Hi Paul,
    One thing I can think of is, what times are you running the Job Queue. It could be a matter of when the job finishes - like by midnight, after midnight as that might be causing it to skip the current date and moving to the next date.
    Also, check your job frequency parameters. If you post the setup of one job where it's happening, we (your NAVUG friends) might be able to assist better.
    Hope this helps.
    ~Meenakshi
    Meenakshi Singh
    Ruby Award Recipient
    NAVUG/D365BC-Programming Committee
  • 3.  RE: NAV 2017 job queues skipping a day
    Posted 24 days ago
    I have attached a couple of job queue screenshots that show our current setup on 2 job queues that are encountering the issue of skipping a day.  This job doesn't have a start and end time because the time to run of the job varies greatly from one day to the next.
    If there are any further suggestions to help resolve the issue it would be appreciated.
    Thanks.
    Paul Connolly
    Diesel Forward
    Windsor WI
  • 4.  RE: NAV 2017 job queues skipping a day
    Posted 21 days ago
    Hi Paul,
     I see a start time for both of these - 2:15 am for the weekday job and 4 am for the weekend job. The parameter you are missing is the total number of minutes between each run, I usually put 2 in there so the system tries it again after 2 minutes if it fails. Did you say the jobs are completing successfully though just skipping a day? The dates seem correct on both jobs though. Also, I always assign priority = 1 for my jobs.
    Meenakshi Singh
  • 5.  RE: NAV 2017 job queues skipping a day
    Posted 25 days ago
    Hi Paul,
    I have experienced this as well, and never found a very good explanation for it. The best workaround I have found is to set the start and end times of the job, and then set the "No. of Minutes between Runs" to that same time interval (assuming you want it to run once per day). For example, Starting Time = 12:00, Ending Time = 12:30, No. of Minutes between Runs = 30.
    Morgan Jansen
    ERP Analyst
    Agropur Ingredients
