Undo Shipment with Lot No. tracking
  • 1.  Undo Shipment with Lot No. tracking
    Posted 5 days ago
    Does anyone know if this is possible? I haven't been able to find a way to do so as of yet. When you do the "undo shipment" you get an error message about the item tracking lines. "Item tracking defined for item ____ in the Sales Line accounts for more than the quantity you have entered. You must adjust the existing item tracking and then reenter the new quantity."
    I can't figure out any way of adjusting the existing item tracking lines.
    Jeff Butler
    CFO
    TCIG
    Winnipeg MB
  • 2.  RE: Undo Shipment with Lot No. tracking
    Posted 5 days ago
    We have performed undo shipments more times than we should and everything is lot controlled.   That seems like an odd error for a reversal of a shipping entry.  Check and see that the quantity on the tracking line matches the sales line quantity.  Were there multiple lots for one sales shipment line?
    October 6-9, 2020
    Nashville, TN
  • 3.  RE: Undo Shipment with Lot No. tracking
    Posted 5 days ago
    Hi Lewis, thanks for your assistance. There were two separate shipments, both of the same lot. Also, we used the apply-to entries, as we were trying to match this shipment with a specific receipt. Hadn't really thought of that, maybe need to do something with the apply to entries, first?
    Jeff Butler
    CFO
    TCIG
    Winnipeg MB
  • 4.  RE: Undo Shipment with Lot No. tracking
    Posted 5 days ago
    We don't typically try to set any apply-to entries on an undo  shipment, so maybe that is complicating things.
    If you have a test environment, you can try reproducing the situation and the error and then maybe you can try a few things there.
    October 6-9, 2020
    Nashville, TN
