Comparison Period Formula field
  • 1.  Comparison Period Formula field
    Posted 17 days ago
    Hello All,
    I am new to Business Central.  I have a LOT of questions....but I'll start with one.
    I created a Custom Column Layout for an Account Schedule for a Balance Sheet
    I need to use the Comparison Period Formula field in the column.  IT IS NOT THERE!
    I can't see anywhere in the setup where to add a a new column.  Can someone tell me where I go to add this field as a column.
    Is it permissions?  Or setup?
    #BC/NAVPlus
    Martin
    Martin Doll
    Aqualis Storm Water Management
  • 2.  RE: Comparison Period Formula field
    Posted 14 days ago
    Martin,
    If you have permissions to Personalize, while you are viewing a Column Layout, click on the gear in the upper right hand corner and select Personalize.
    If you have the permission to Personalize, you should see the following:
    When you select the +Field, you will see the fields you can add to the Column Layout.
    Robb Delprado
    Senior Trainer and Consultant
    robb@newviewstrategies.com
    860.558.8032
    Houston, TX
  • 3.  RE: Comparison Period Formula field
    Posted 14 days ago
    Perfect.  Thanks.  Appreciate the help.
    Martin Doll
