lookup value from item record in invoice
  • 1.  lookup value from item record in invoice
    Posted Jan 07, 2020 09:05 PM
    Hi All
    I'm working on a report in C/AL and need to get a field (from an add-in ) fromt he item record
    Field is called "Container Code"
    i created a global var of type Code 10 called gContainerCode
    I then created a local var called recItem in "Line - OnAfterGetRecord()"
    I then added this code
    //find the item record whose no matches invoice line's item no
    recItem.SETRANGE("No.",Line."No.");
    // if a record found, get the container code, else return nothing
    IF recItem.FINDFIRST THEN
      gContainerCode := recItem."Container Code"
    ELSE
      gContainerCode := '';
    I don't get any errors :-)
    but i don't get a value either :-(
    Anyone got any ideas?
  • 2.  RE: lookup value from item record in invoice
    Posted Jan 08, 2020 09:15 AM
    Your code looks like it would work....So next step is to use the debugger. Maybe that particular item doesn't have a container code? Maybe the "Line" record isn't an item line or doesn't yet have the "No." field populated. With the debugger you should be able to figure out what's not working.
    Also, (just a tip) rather than using SETRANGE and then FINDFIRST, it would be more efficient in this case to just use:
    IF recItem.GET(Line."No.") THEN ... ELSE ...;
    Kaukauna WI
  • 3.  RE: lookup value from item record in invoice
    Posted Jan 09, 2020 06:44 AM
    Thanks Greg
    Came in next morning and it seemed to work
  • 4.  RE: lookup value from item record in invoice
    Posted Jan 08, 2020 10:38 AM
    Hi Mark,
    Two things.  Your code should work fine, but if you have the primary key value, you can use a GET statement:
    CLEAR(gContainerCode);
      gContainerCode := recItem."Container Code";
    If that doesn't work, check that the Item you're looking at has a valid Container Code.  If it does, try running the debugger and see if the Line record has the correct "No." value when your code is executing.
    Andrew Drott
    ERP Lead
    Gogo, LLC
    Broomfield CO
  • 5.  RE: lookup value from item record in invoice
    Posted Jan 09, 2020 06:48 AM
    Thanks Andrew
    Came in next morning and it worked. Thanks for tip on "GET"
  • 6.  RE: lookup value from item record in invoice
    Posted Jan 09, 2020 10:40 AM
    Short follow up, if I need to get 3 fields from the same item record, what would be most efficient way?
  • 7.  RE: lookup value from item record in invoice
    Posted Jan 09, 2020 10:51 AM
    I would just get the Item record, then reference the fields directly (i.e. recitem."No.", recItem.Description, recItem."Container Code").
    You'd only really need to use a variable to store the values if you want to manipulate them or use it at a later time outside the OnAfterRecord trigger.
    Andrew Drott  ERP Lead Developer
    Gogo Business Aviation  |  105 Edgeview Drive  |  Broomfield, CO 80021  |  USA  |  O: +1 303 301 3320  |  M: +1 312 231 8085
  • 8.  RE: lookup value from item record in invoice
    Posted Jan 10, 2020 07:02 AM
    Thanks Andrew
  • 9.  RE: lookup value from item record in invoice
    Posted Jan 08, 2020 11:02 AM
    One other thought here that's gotten me in the past. Since the Container Code field is an addon and not standard NAV, I have no idea what type of field it is, but if it's a Flowfield type (look at the Item table, and look at the Properties of that Container Code field), then you will have to add another little piece of code so it looks something like this:
    IF recItem.FINDFIRST THEN BEGIN
      recItem.CALCFIELDS("Container Code");
    END ELSE
    Just one more thing to check...
    Good Luck!
    Jim Brewer
    Silverware
    beaverton AZ
  • 10.  RE: lookup value from item record in invoice
    Thanks Jim
    Started working inexplicably next morning
    Thanks for tip on FlowFields
  • 11.  RE: lookup value from item record in invoice
    Posted Feb 18, 2020 04:33 PM
    Thanks Jim (bit of a belated reply)
  • 12.  RE: lookup value from item record in invoice
    Posted Jan 08, 2020 11:57 AM
    The "Container No." field on the Item record isn't a FlowField is it?  If so, you'd have to do a calcfield on it.
    Christopher Boyle
    iCepts Technology Group, Inc.
    Middletown PA
