Export to Excel
  • 1.  Export to Excel
    Posted 10 days ago
    Hi All,
    I am trying to Export general ledger activity, vendor activity, etc to Excel.  When I click on Print & Send to Excel, it asks me to save the file instead of opening it in Excel.  I think I accidentally clicked on save instead of open once last week and now it doesn't even give me the option.  Does anyone know how I can fix this?
    Thank you.
    Frank Murray
    PECO Pallet, Inc.
    Irvington
  • 2.  RE: Export to Excel
    Posted 10 days ago
    Do you use the Print feature and then choose Excel, in version 2017/2018 or are you using an earlier version? Have you tried just using Ctrl+E, the shortcut?
  • 3.  RE: Export to Excel
    Posted 9 days ago
    Hi Kim,
    Yes, I hit print and then choose Excel.  We are using NAV 2016.  I did try using the Ctrl+E but it asked to save as well.
    Thanks.
    Frank Murray
    PECO Pallet, Inc.
    Irvington
  • 4.  RE: Export to Excel
    Posted 9 days ago
    Not sure when this happened but in 2017 and 2018, I get prompted to save the Excel file when using Ctrl+E and then I noticed a sneaky little check box.
    I unchecked the box and it no longer displays this screen, it just opens Excel with the data.
    Hope this helps.
  • 5.  RE: Export to Excel
    Posted 9 days ago
    Hi Kim,
    I tried the Ctrl+E and the pop up I get doesn't give me the option to uncheck anything.  it is just a normal save box with the folders list.
    Frank Murray
    PECO Pallet, Inc.
    Irvington
  • 6.  RE: Export to Excel
    Posted 9 days ago
    It sounds like NAV thinks the print window is still open somehow.  Have you tried opening the printer window (print > print, not the Excel option) to see if it has the Send To. option available?  Newer versions of NAV and BC has that option.
    Jason Nicolaou
    Engagement Manager
    Sikich, LLP
  • 7.  RE: Export to Excel
    Posted 9 days ago
    Hi Jason,
    I just tried the Print option and it just prints to paper.
    Frank Murray
    PECO Pallet, Inc.
    Irvington
  • 8.  RE: Export to Excel
    Posted 8 days ago
    This is not a NAV setting but rather a registry setting on windows.  I can't seem to find the correct article that explains how to re-enable this.  Basically you need to go into the registry and create or reset one of the keys.  If I find out how to do this I will respond, but you might need a Microsoft ticket to solve this.
  • 9.  RE: Export to Excel
    Posted 8 days ago
    Consider uninstalling Excel and reinstalling it along with Nav Add-in. Might be faster than finding the cause.  Unless it's so obvious you have already tried it.
    Michael Carr
    VP , Finance
    Philadelphia Scientific LLC
    Montgomeryville PA
