Does a Lanham EShip report exist that displays data uploaded to UPS ?
  • 1.  Does a Lanham EShip report exist that displays data uploaded to UPS ?
    Posted Apr 26, 2019 10:39 AM
    The posted packages information from the Posted Manifest query does not display all the information that is uploaded to UPS.
    We found the rate file Lanham provided us at the first of the calendar year only calculated Declared Value charges at 90 cents per hundred, not the
    $1.05 per hundred put in place for calendar 2019.
    The XML format is too difficult to interpret without a formal report.
    We want to monitor the information daily,  not only from the weekly UPS Invoice download.
    Thank you
    Michael Heatherly
    controller
    Lesman Instrument Company
    BENSENVILLE IL
  • 2.  RE: Does a Lanham EShip report exist that displays data uploaded to UPS ?
    Posted Apr 29, 2019 05:42 PM
    There are a few things going on here.
    1. There is a report, Manifest Report 14000706, which will give you the information you want.
    2. You mention a query that sounds like it might be something custom you or your partner created for you so I can't really address that.
    3. In February, we sent a Tech Alert to inform all UPS customers that a change was needed to the rate files published earlier. It sounds like you did not get that update. You will need to contact your Lanham partner for that update.
    4. You might also consider the Invoice Reconciliation module which has methods to quickly isolate any shipping cost discrepancies by comparing carrier invoice cost to calculated cost. If you want more information about that, please let me know
    Jim Augenstein
    Channel Manager
    Aliso Viejo, CA
