Prod. Order "Ending Date" stops at 3/1/19
  • 1.  Prod. Order "Ending Date" stops at 3/1/19
    Posted 26 days ago
    When filing out a production order, the "Ending Date" field within the "Schedule" tab is unable to go passed 3/1/2019. Typically, the user selects a due date from the general tab (header) and then upon selecting "Refresh Production Order", that date is populated in "Ending Date". However, now when the user selects a due date that is > 3/1/2019, and then refreshes production order, the ending date field defaults to 3/1/2019.
    Any suggestions on the reasoning behind this behavior? Where would I look to fix the issue?
    Help is much appreciated!
    Matt Cameron
    Marine Ingredients
    Mount Bethel PA
  • 2.  RE: Prod. Order "Ending Date" stops at 3/1/19
    Posted 26 days ago
    Edited by Lewis Rosenberg 26 days ago
    ​My guess is that your shop floor calendar is not defined past March of 2019.
    Go to Manufacturing > Capacity and then Work Centers.  Check the Work Center Calendar.
    Here's some more information:   How to Create Work Center Calendars
    #Manufacturing
