Inventory by Lot Bin
  • 1.  Inventory by Lot Bin
    Posted Jan 03, 2019 10:42 PM
    I am trying to understand connection between Warehouse Entry and Item Ledger Entries.  I need Lot, Item, Expiration Date, and Quantity data.  ILE seems to be keeper of data but how do I connect ILE to bins?
    Simon Jackson
    Information Systems Manager
    Manzana Products
    Sebastopol CA
  • 2.  RE: Inventory by Lot Bin
    Posted Jan 04, 2019 08:32 AM
    ​Have you tried looking at the Warehouse Entries?  Bins/Lots are housed there and you might be able to tie using a Doc/Source No.
    Jessie Sanger-Picard
    NAV Level II Support Lead
    Forum Energy Technologies
    Houston TX
  • 3.  RE: Inventory by Lot Bin
    Posted Jan 04, 2019 09:13 AM
    Hello Simon,​
    Think of the Item Ledger Entry table as the fiinancial data source or inventory summary table.  You can find all of the information you listed there (item, lot, expiration date, quantity).  The Warehouse Entries tracks inventory transactions by bin.
    There is a Lot Numbers by Bin factbox that you can display on Bin Contents (Departments > Warehouse > Planning & Execution:  TASKS - Bin Contents) that will show what lot can be found in what bin.
    Lot Numbers by Bin
  • 4.  RE: Inventory by Lot Bin
    Posted Jan 04, 2019 09:24 AM
    Hi Simon,
    If your Lot's are recorded in the Warehouse Entries, then you should be able to get everything you need from Warehouse Entry.  See if "Lot Warehouse Tracking" is checked on the Item Tracking Code Card.  If so, then the Lot information should be in the Warehouse Entry Records.
    If you are trying to get the information you are looking for from within NAV then you can just go to the "Bin Contents" Page and set your filters.  Bin Contents are simply summing Warehouse Entries for the filters you set.  To Set a Filter for a specific Lot Number, you will need to use the "Limit Totals" Filter Option.
    If you are trying to do this outside of NAV (like a SQL Query).  You will do the same kind of thing on the Warehouse Entry Sum the Quantity grouped by Item, Lot and Bin.
    If the Lot is not tracked in the Warehouse Entry there isn't a real great "connection" of these two tables.  There is a table called "Whse. Item Entry Relation", but it doesn't necessarily tie specific ILE's to Warehouse Entry records.  I think you might be able to use this to make your connection, but it would not be a simple JOIN.
    Joe Draeger
    Ortho Molecular Products, Inc
    Woodstock IL
