SQL Error " Could Not find Prepared Statement with Handle 12511"
  • 1.  SQL Error " Could Not find Prepared Statement with Handle 12511"
    Posted 15 days ago
    Edited by Guy Famelart 15 days ago
    It looks like it is coming from Web services
    SQL is setup with unlimited connections
    Anybody got this error and a solution to fix it.
    We are on NAV 2017
    Guy Famelart
    Senior Manager of IT
    Skyfold inc.
    Baie d'Urfé QC
  • 2.  RE: SQL Error " Could Not find Prepared Statement with Handle 12511"
    Posted 2 days ago
    Hi Guy,
    I am not sure, if this is still an issue. Since I am not sure what SQL version you are using, it could be a lot of things. There are different topics around that when you search for the error message, but they are all pointing to different things. One of the main things seems to be that, if you are running on an older SQL Server and the version is not supported, it can throw errors like that. Another topic points to some possible issue in the NAV server, but this is for an older version.
    So, what version of SQL are you using?
    Does this happen all the time (as soon as you start and work in NAV) or only once in a while?
    Do you have a way to replicate this behavior?
    Peter Zentner
    Director of Product Management
    NAV-X
    Holmdel NJ
  • 3.  RE: SQL Error " Could Not find Prepared Statement with Handle 12511"
    Posted 17 hours ago
    Need more information. What is a user trying to do when the error message happens? Where are you seeing the error message - in a client? In SQL logs? In the server event viewer?
    Kyle Hardin
    Duluth GA
