Easy Security and Change Log
  • 1.  Easy Security and Change Log
    Posted Oct 02, 2019 09:45 PM
    ​​We recently re-implemented to NAV 2017 and are now looking at adding additional controls through Easy Security. One question I can't find an answer to, since I've never done anything with Change Log, is whether Easy Security makes accessing the Change Log easier. I actually don't know anything about Change Log, but we're having a few growing pains as our department expands and tightening down permissions has become an urgent matter. I need to know if - once we set up specific users with specific permissions - we will be able to run reports to ensure the guidelines set up for those permissions have been followed. (i.e. proper documentation for adding a new vendor, etc.)
    I guess my question is this: will Easy Security make it easy to determine which users have performed which specific actions we're watching, or do I just need to learn how to use the standard NAV Change Log? I'm heading into crunch time to get this scheduled and need to have answers for our CFO.
    Thanks for any insight!
    Tara Langley
    Accounting Manager
    Prairie du Sac WI
  • 2.  RE: Easy Security and Change Log
    Posted Oct 03, 2019 12:45 AM
    ES will not make the change log easier, you just need to learn how to use the standard NAV change log (It's not that hard)
    Erik Hougaard
    MVP
    E Foqus Danmark A/S
    North Vancouver BC
  • 3.  RE: Easy Security and Change Log
    Posted Oct 03, 2019 08:14 AM
    Easy Security would help you manage security but not monitor what is happening. Using the Change Log will capture changes in the data. You will likely need to write additional reports on the change log data to review and audit the transactions.
    Marcus Haug
    Stoneridge Software
    Fargo
  • 4.  RE: Easy Security and Change Log
    Posted Oct 03, 2019 08:38 AM
    ​In addition to Easy Security (which the above responses are correct - will not help with audit tracking of data changes) we also use Lanham's History management add-on.  My users love it.  When you configure change tracking on a table it can install buttons on the associated pages to allow users to see change detail from within that page (see attached).  It allows  my users to get that information themselves without going to IT.   If you'd like more information feel free to contact me or go to Lanham's website.
    Linda Hart
    VP of Information Technology
    Prince & Izant
    Parma Hts OH
  • 5.  RE: Easy Security and Change Log
    Posted Oct 03, 2019 09:19 AM
    Similar to Lanham's add-on, I've added buttons to many common areas that pop open a filtered view of the change log. This a quick way to access what you're looking for.
    Kaukauna WI
  • 6.  RE: Easy Security and Change Log
    Posted Oct 04, 2019 09:26 AM
    The change log entries generate 1 line (entry) for each field you select to monitor in the change log setup.  I highly recommend choosing the fewest fields possible on the fewest tables.  My VAR originally set us up to monitor all fields on the Sales Header, Sales Line, Purchase Header and Purchase Line.  1 year later the change log entry table was so large it was no longer reasonably accessible in NAV.  We ended up having a developer delete the entries using SQL, then greatly reducing the fields.  For instance, on the sales lines we now only track Item No., Qty and Amount.
    Mark Buckingham
    Signature Systems Group, LLC
    Flower Mound TX
  • 7.  RE: Easy Security and Change Log
    Posted Oct 07, 2019 09:38 AM
    Good to know @Mark Buckingham! Thanks​ for the word of warning.
    Tara Langley
    Accounting Manager
    Prairie du Sac WI
