Retainge Withholding Setup In Dynamics Nav 2017
  • 1.  Retainge Withholding Setup In Dynamics Nav 2017
    Posted 11 days ago
    Hi
    I need help on the setup of the ratainage in NAV 2017
    I want to change the g/l code that the retainage is set to post
    Where can i change the retainage g/l code
    Thanks for the help
    Yusuf
    Yusuf Newland
    MGAC
    Washintgon DC
  • 2.  RE: Retainge Withholding Setup In Dynamics Nav 2017
    Posted 11 days ago
    Not clear on what you mean by retainage.  Can you provide an example?  Are you referring to Retained Earnings?  If so, BC/NAV uses the account specified in the runtime options when you run the "Close Income Statement" function.  There is no setup for this.  If you're referring to something else, some additional context would be appreciated.
    Sr. Solution Consultant
    2019-2020 Board of Advisors
    BCUG|NAVUG All-Star
  • 3.  RE: Retainge Withholding Setup In Dynamics Nav 2017
    Posted 10 days ago
    Hi David
    Thanks for the reply
    I was trying to edit the GL for the Withholding on the Dynamics NAV 2017
    I was able to do from the Project Accounting Setup
    Thanks again for reaching out
    Yusuf
    Yusuf Newland
    MGAC
    Washintgon DC
  • 4.  RE: Retainge Withholding Setup In Dynamics Nav 2017
    Posted 10 days ago
    Hi Yusuf -
    It sounds like you may be using Job Manager from Cost Control.  If so, you will find the "Retainage G/L Acc." field on the Customer Posting Groups screen.
    -Michael
    Michael Martin
    Silverware
  • 5.  RE: Retainge Withholding Setup In Dynamics Nav 2017
    Posted 10 days ago
    Hi Mike
    I was able to do it from the Project Accounting Setup on Dynamics NAV 2017
    Thanks so much for reaching our
    Truly appreciated
    Yusuf
    Yusuf Newland
    MGAC
    Washintgon DC
