Item Attributes Factbox Missing Information
  • 1.  Item Attributes Factbox Missing Information
    Posted 24 days ago
    We are going to use attributes for items but the information is not showing up in the Factbox when entered.  In 3 of the attributes I added as a test the Value shows up but not the name.  Then I added one more and neither name or value shows up.   Any ideas?  We're on Nav 2017.
    Patti Parrish
    ERP Systems Finance Lead
    Alpharetta, Ga
  • 2.  RE: Item Attributes Factbox Missing Information
    Posted 23 days ago
    It appears to be an issue with NAV 2017. Check to see if it is fixed in one of the cumulative updates. It works in NAV 2018.
    Andrew Good
    Oakbrook Terrace IL
  • 3.  RE: Item Attributes Factbox Missing Information
    Posted 23 days ago
    Patti,
    Happy New Year. I tested this and recreated in my BC 17.2 version. Here is an image.
    To resolve, search for Item Attributes. In the list select, one by one, the Attribute that is the issue. Mine is Color.
    Then click Translations. Look at mine below. Since I set one up and left the Name field blank, it appear blank. If I delete the translation record, it reappears (pic 2 below).
    Hope this helps.
  • 4.  RE: Item Attributes Factbox Missing Information
    Posted 23 days ago
    Which build of 2017 are you running? I recall there being some updates around CU12. Also, do you have all the columns visible? There are two sets of "Name" and "Value" that all should be displayed.
    Brad Prendergast
    Edmond OK
