Export info out of NAV2015 into an existing spreadsheet
  • 1.  Export info out of NAV2015 into an existing spreadsheet
    Posted 14 days ago
    Hi everyone-
    Let me explain what I am trying to do. I have an existing spreadsheet that is a product catalog. Basically the spreadsheet has the following fields from the item card:
         Part Number, Description, and Unit Price
    The spreadsheet has all of that, plus a picture of the product. We had a price change and I want to import the data into the spreadsheet as either a change for an existing part number or if the part number is not in the spreadsheet to add it a new line with the part number, description and unit price.
    Does anyone has any idea how to go about this? Is this something that can be done in Jet Report. Which we have, but I don't know how to use it.
    Any ideas or suggestions would be grateful. Thank you in advance.
    Randy Duly
    Bulldog Battery Corporation
    Wabash IN
    NAV 2015
  • 2.  RE: Export info out of NAV2015 into an existing spreadsheet
    Posted 13 days ago
    Edited by Lewis Rosenberg 13 days ago
    Randy, I am not sure about images, but Jet Reports can be used to report on any of your BC/NAV data (in Excel).  RapidStart can also be used to export data like your item numbers, descriptions, and prices, but you cannot design a format for the data to be exported to.  It will only be exported into a simple Excel table.
    [EDIT]:
    You could probably add the images as a static element in a Jet Report and let Jet Reports refresh to obtain current items and prices.
    D365UG-BC/NAVUG All-Star
  • 3.  RE: Export info out of NAV2015 into an existing spreadsheet
    Posted 12 days ago
    Thank to everyone who have responded with their suggestions. I appreciate it.
    Sincerely,
    Randy Duly, IT Specialist
  • 4.  RE: Export info out of NAV2015 into an existing spreadsheet
    Posted 12 days ago
    There is the NAV 2015 Excel Addin that should let you have a "refreshable" spreadsheet.
    You're probably best off to have 2 workbooks.  1 has your data from excel. 2 has your product data with pictures etc...  Then you join the two spreadsheets (see if MS Power Query will do this - native to Excel - easy to use).
    You might also be able to have a sheet in your master workbook.
    Finally ... ODATA would work.  I have a blog on using ODATA ... https://www.sabrelimited.com/blogs/odata-with-business-central/
    The blog is for Business Central but the same technique should work in NAV 2015 if memory serves me right.  I'm pretty sure the ODATA web services were in that version.
    Sabre Limited
    Cambridge
    robert@sabrelimited.com
  • 5.  RE: Export info out of NAV2015 into an existing spreadsheet
    Posted 11 days ago
    Thank you I will have to look into this.
    Sincerely,
