NAV 2017 historical data cleanup
  • 1.  NAV 2017 historical data cleanup
    Posted Nov 15, 2019 07:19 AM
    Edited by Don Danko Nov 15, 2019 11:35 AM
    We are running NAV 2017 and have records in the database going back to 2008. We would like to possibly archive older data to improve overall performance when pulling up lists or running reports in NAV as well as reporting on the data in our BI solution. There is a section in NAV administration for 'Data Deletion' that includes deletion of various documents and also date compression on ledger entries. Has anyone had experience using the date compression function in NAV or performed archival of older records to access for reporting purposes?
    Don
    Don Danko
    Dukal Corporation
    Ronkonkoma NY
  • 2.  RE: NAV 2017 historical data cleanup
    Posted Nov 16, 2019 11:43 PM
    I have some experience with the Data Deletion tools.  Send me a IM and we can talk.
    Client Lead
    2019-2020 Board of Advisors
    BCUG|NAVUG All-Star
  • 3.  RE: NAV 2017 historical data cleanup
    Posted Nov 18, 2019 07:07 AM
    I'm interested in this too
  • 4.  RE: NAV 2017 historical data cleanup
    Posted Nov 18, 2019 08:14 AM
    Don,
    We use the Date Compress Whse. Entries often, we try to run it quarterly, period length Year, retain serial and lot numbers, we set the ending date three months back as occasionally it's useful to examine recent entries.
    We've not ever used the G/l Entries task, but it's one we are considering.
    John Bellinger
    Business Systems & Applications Manager
    Office: 952-392-3912 | Cell: 612-719-0289
    Activar, Inc.
    9700 Newton Ave. S. | Bloomington, MN 55431
    jbellinger@activar.com | www.activar.com
  • 5.  RE: NAV 2017 historical data cleanup
    Posted Nov 19, 2019 06:29 AM
    Hi Don,
    We have the same issue as we have data since 2004.
    I used some default cleaning tools of Dynamics, but in our situation they didn't work.
    Compressing VAT ledger entries took more than 1 day, to do just the first year (in TEST).
    If we want to do this on a live environment for all years, we need to close the business.
    We made some code, which is now running on a weekly base to delete records.
    For instance all shipment lines are not relevant in our case, after a couple of months.
    We don't create invoice lines with qty zero anymore, a back order report is created seperately based on the order.
    We delete segments older than 3 years, we delete warehouse entries when there is no stock anymore in a bin (older than 18 months).
    Our large tables have 20 to 50 mln records, 50 mln in the GL-Entry.
    If there is some who alternatives, I'm interested.
    Annette van der Muur
    Application Manager
    Hal Leonard Corporation
