How to add a new button in NAV to launch other apps
  • 1.  How to add a new button in NAV to launch other apps
    Posted Aug 01, 2019 05:40 PM
    Can you customize the ribbon in NAV to launch other applications.
    I.E from the production page I'd Like to add a link to our SDS sheets so that a user would be able to go directly to a shared folder.
    Or be able to pull up an external spreadsheet with a jet report directly from a session in Nav.
    Is this possible?
    John Gaither
    American Art Clay Co
    Indianapolis IN
  • 2.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 01, 2019 06:52 PM
    It's possible each situation may require different coding solution. What version are you running?
  • 3.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 02, 2019 08:31 AM
    2018 on prem
    John Gaither
    Indianapolis IN
  • 4.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 02, 2019 07:09 AM
    My dear John, Anything is possible in NAV....how much do you want to spend is the real question!  I would call this a great Phase 2 opportunity :)
    Holly Kutil ~ NAVUG All-Star
    Customer Success Manager
    ♥♥ Women In Dynamics ♥♥
  • 5.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 02, 2019 08:24 AM
    John,
    You can use the Links capability to go directly to the file (one link per file) or to open a specific folder (one link to the folder).  The folder is a little trickier, but the functionality is the same.  You would display the available Links in a Factbox, not directly in the Ribbon.
    If you are trying to open another program (i.e. CAD), if the file type requires that program it will open that program (assuming it is available on the workstation).  If you don't have a specific file and want to open a program, then a button in the ribbon would be your programming choice.
    Best Regards,
  • 6.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 07, 2019 05:15 PM
    Looks like the link function will do what we need.  I can't figure out where the link data is stored?  I need to update this link on several hundred items.
    John Gaither
    Indianapolis IN
  • 7.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 07, 2019 07:42 PM
    It's stored in the Record Link table so you should be able to update it there or export it and update it using Excel via Rapid Start
    ~Meenakshi
    Meenakshi Singh
    Home Market Foods, Inc.
    Norwood MA
  • 8.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 07, 2019 11:44 PM
    I tried to setup a rapid start template for table 2000000068 but it tells me I can't use the system table in the package.  I don't see any sessions except for the link on the item card.
    It's doable but going through 600 items and attaching this link manually seems to be a little tedious.
    John Gaither
    Indianapolis IN
  • 9.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 02, 2019 09:13 AM
    Hi John,
    You can certainly customize and add a new button in the ribbon to open a new link to a spreadsheet etc.
    Links functionality is another way of achieving it and opening files in a shared drive.
    In both scenarios, you need to make sure the users as well as your NAV service account has access to that shared drive/folder/file to be able to open it.
    ~Meenakshi
    Meenakshi Singh
    Norwood MA
  • 10.  RE: How to add a new button in NAV to launch other apps
    Posted Aug 02, 2019 09:25 AM
    If you're wanting to open other programs with code, a brief search indicates you're looking at dotnet coding. Here's a couple links:
    https://community.dynamics.com/nav/f/microsoft-dynamics-nav-forum/270960/best-practice-to-run-an-external-program-from-nav-codeunit
    https://community.dynamics.com/nav/b/moxie4nav/posts/executing-external-programs
    Kaukauna WI
