  • 1.  Dynamics Nav Sales Connection to CRM
    Posted May 06, 2020 10:06 AM
    Dear Team,
    I am using the Dynamics Nav(Nav2018) Sales Connection to CRM tool.
    Integration on defaults settings is ok. but i would wish to expose other Fields to be synchronized to CRM 2016(on premise)
    • Vendor Card information.
    • Item Card.....Extra Fields.
    Where  or how easily can i customize this?
    Stanislaus Banda
    Head of Supply Chain and ICT
    Osho Chemical Industries ltd
    Nairobi
  • 2.  RE: Dynamics Nav Sales Connection to CRM
    Posted May 07, 2020 09:35 AM
    Edited by Greg Enns May 07, 2020 09:35 AM
    It's fairly easy to add additional fields to an existing mapping. Just use the "Integration Field Mapping" table in conjunction with the "Integration Table Mapping". For the Vendor integration, you'll need to add a new integration Table Mapping which is more complex. You'll need to use the NAV Development Shell to create the "CRM Vendor" table as a .txt file and then import that new object into NAV. There is more, but the key things then are you'll need to setup the Integration Table Mapping and the related Integration Field Mapping.
    The integration definitely changed some after NAV 2016, but check out my video on the 2016 integration to get an idea of what all is needed: https://www.youtube.com/watch?v=etJ7hT6Dquo
    Appleton WI
  • 3.  RE: Dynamics Nav Sales Connection to CRM
    Posted May 07, 2020 10:30 AM
    Thank You Greg for this Feedback, i will go through the Video and give it a try.
    Stanislaus Banda
    Nairobi
