Over-posting to Released Production Orders
  • 1.  Over-posting to Released Production Orders
    Posted Jan 30, 2020 04:04 PM
    We are running BC 365 on-premise [but the problem was noticed in 2013R2, also].
    Is there any way to prevent our work floor from over-posting to an open order?
    For example: RO is open for 200, if there are enough raw materials at location, nothing prevents the work floor from posting 250 units to this job.
    Is there a way to stop the additional posting?
    [Beth] [Kneisler]
    [Data Analyst/Programmer]
    [Valley Packaging Industries Inc]
    [Appleton] [WI]
  • 2.  RE: Over-posting to Released Production Orders
    Posted Jan 30, 2020 05:46 PM
    Standard NAV/BC allows you to produce more than the Production Order Qty and you should be able to see the cost variances.
    Are they "over-posting" in error or are they actually producing more than what the order called for?
    NAVUG/D365BC-User Group Focus
    May 18-19, 2019
    Denver, Colorado
  • 3.  RE: Over-posting to Released Production Orders
    Posted Jan 31, 2020 09:05 AM
    over-posting in error -  posting a partial pallet before break, then re-posting the same pallet after.
    EX: pallet = 40 cases.
    cases produced before break = 21
    cases posted = 21
    cases produced after break = 19 [pallet completed]
    cases posted = 40
    Many of our jobs are not typically very large, so all of the required materials are brought to the line as part of the setup. So until the materials run dry, they can post whatever. If the materials never run out, there is no limit to what can be posted to the job. Backing out the transactions requires a whole lot of extra effort from other departments. I was just wondering if there was some way to put a hard stop on certain orders.
    [Beth] [Kneisler]
    [Appleton] [WI]
  • 4.  RE: Over-posting to Released Production Orders
    Posted Jan 31, 2020 10:08 AM
    Beth - As Lewis stated by design NAV/BC allows posting more Output than planned. To not allow over posting would require a modification. There is a setup available to replace reporting and posting output with an auto-post of the planned Output when the Production Order is finished but this setup is not always practical to a company's process - for large quantity longer running production orders as an example..
    Best Regards
    John
    John Grant
  • 5.  RE: Over-posting to Released Production Orders
    Posted Feb 03, 2020 10:41 AM
    We had this same problem, and since we don't ever do over-postings, I did a modification on the post to check for that and error out when the qty is already posted.
