BC Bugs
  • 1.  BC Bugs
    Posted 26 days ago
    I'm looking for the best method of reporting bugs for BC...
    For example, I've found 2 bugs in the code related to the BC CRM Integration...where/how should I submit those?
    Thanks in advance!
    Appleton WI
  • 2.  RE: BC Bugs
    Posted 26 days ago
    Hi Greg,
    You can report any bugs to your partner.  You can also post them on the ideas site:  https://experience.dynamics.com/ideas/
    October 6-9, 2020
    Nashville, TN
  • 3.  RE: BC Bugs
    Posted 26 days ago
    Perfect! Thanks!
    Appleton WI
  • 4.  RE: BC Bugs
    Posted 26 days ago
    I agree with Lewis. If you report them to your partner then your partner will create a support ticket with the details. I've had good luck doing this and Microsoft has been able to fix everything in a timely manner once they're notified of it.
    Kristen Hosman
    Independent Dynamics ERP Consultant
    Mount Evans Consulting LLC
    Pine CO
  • 5.  RE: BC Bugs
    Posted 25 days ago
    The "Ideas" site has an FAQ that specifically says it is NOT for bugs in the product.
    So, if you're on-prem like me, then it looks like having you partner report bugs on your behalf is your only option.
    For those with BC in the MS cloud, you can create your own support tickets through the D365 Admin center. (I've done this for CRM Online with great success.)
    As a sidenote, (thanks to @Mary Bricco for the reminder) you can post Docker/BC-related issues in the GitHub site for Docker/BC​: https://github.com/microsoft/nav-docker/issues
    Appleton WI
  • 6.  RE: BC Bugs
    Posted 26 days ago
    Use this site-
    Mary Bricco
    Dynamics 365 Business Central/NAV Consultant
    Boyer & Associates
    New London WI
