Uploading a Purchase Invoice with 300 lines
  • 1.  Uploading a Purchase Invoice with 300 lines
    Posted 6 days ago
    We currently have a few invoices to process that has over 250 lines of coding and looking for options to load data.
    The options provided to load the PI lines are:
    1) Copy Paste - this is taking a couple hours as lines are validated - is this typical
    2) Rapid Start template - this tool is not for end users as it accesses tables directly
    3) XML import routine - this is used for specific vendor integrations
    Would welcome any thoughts on options to load these large records.
    Regards,
    Deanna
    Deanna Hutchins
    Strad Energy Services Ltd
    AB
  • 2.  RE: Uploading a Purchase Invoice with 300 lines
    Posted 6 days ago
    ​RapidStart will work according to how you have NAV permissions set up.  A user can use RapidStart, but they would need access to RapidStart PLUS access to any tables to be updated.
  • 3.  RE: Uploading a Purchase Invoice with 300 lines
    Posted 5 days ago
    ​Thank you for the information.  My understanding is that Rapid Start is not a tool for end users to use on a day to day bases due to how it updates the tables directly so a risk from a controls perspective. Can you please confirm?
    Deanna Hutchins
    AB
  • 4.  RE: Uploading a Purchase Invoice with 300 lines
    Posted 5 days ago
    #DataManagement
    We've tried using RapidStart for importing sales and purchase orders and it is extremely slow.  Could take over an hour for 10 lines.
    We typically create XML ports for importing orders.  Add a button on the page, so the user can access it quickly.  Provide them a
    template for their import(s).
    Good Luck!
    Dori Ellinger
    Dori Ellinger
    Solution Systems, Inc.
    Rolling Meadows IL
  • 5.  RE: Uploading a Purchase Invoice with 300 lines
    Posted 5 days ago
    We import directly from excel.  I have written a process to import the lines from excel.  The user selects the excel file and then which tab from excel they want to import.
    It loads 100 lines in less than 5 seconds.   I have built it so that it if there are any errors, it opens a new excel file with the lines that errored out and they can then fix them and load the remaining items.
    Ahmed Amini
    Indepedant Consultant
    Scotts Valley CA
  • 6.  RE: Uploading a Purchase Invoice with 300 lines
    Posted 4 days ago
    I would generally recommend copy & paste from Excel as a simple solution suitable for most users.  Validation taking hours sounds very strange.  You could try pasting smaller amounts each time, and see if it works better with 50 lines at a time.
    Eric Moe
    Global Supply Chain Manager
    Industrial Revolution
    Tukwila WA
  • 7.  RE: Uploading a Purchase Invoice with 300 lines
    Posted 18 hours ago
    I would suggest having imported in custom tables having the similar structure of Purchase header and Purchase line without any code in any trigger.
    Then to import you can use any feature, it should be fast enough but if its something that you will be doing any a process to follow I would suggest using xmlports or a codeunit that you can schedule to run to read files from a folder and import it in nav and then move to processed folder.
    After the import is successful another job queue can try to generate purchase invoices from data in custom tables and update the status on the same table if any errors. If records are processed process will delete the records from custom tables.
    Saurav Dhyani
    Duluth GA
