Just based on the "No recipients have been specified" message, this sounds like more of a data issue than an SMTP issue. Are you sure your workflow is able to properly assign the recipient of the email? Check what field it is getting the email from and make sure all records have a proper email assigned. If it is selecting a Contact or User, are you sure they have a proper email on the record?
Carmel, IN
Sent: Jan 12, 2021 04:19 PM
Subject: Workflow Notification E-mails Not Sending
We are having an issue where the out of the box workflow notification is not sending the e-mails in BC. There is an error in the job queue - A call to MailKit.Net.Smtp.SmtpClient.Send failed with this message: No recipients have been specified.
We can send a test e-mail successfully from the SMTP Mail Setup - to people within the domain and to people outside the domain. It is only in the job queue that it is failing - and it fails for both people in the domain and people out of the domain.
We believe this is an SMTP issues instead of BC, but there doesn't seem to be much info out there on this specific error message. G Suite is being used for SMTP.
Anyone have this issue before and know what SMTP settings need changed to fix it?
Marisa Goodfellow
Wolcott Group
Medina OH
