1.  Eliminating blocked items from purchase quotes item selection
Posted 9 days ago
Running NAV2015, we have recently revised the list of purchasing items which resulted in many items going out of use.  Although the items are blocked, they
keep showing in the drop down list upon creating purchase requests / orders.
Is there a setup option that would exclude the blocked items from the drop down list ?
Thanks in advance !
2.  RE: Eliminating blocked items from purchase quotes item selection
Posted 9 days ago
I wish there was a setup option but there is not it take a small customization to hide blocked items.
VP Professional Services
Syte Consulting Group
kdallefeld@sytecg.com
3.  RE: Eliminating blocked items from purchase quotes item selection
Posted 8 days ago
​Hi Shacham,
Kim is right there is no setting. When we demo, we generally do as Kim suggested and add a small line of code to filter out blocked items.
Jenn Morton
Manufacturing Consultant
Sabre Limited
Cambridge Ontario Canada
4.  RE: Eliminating blocked items from purchase quotes item selection
Posted 8 days ago
It's pretty simple... pretty much just filter out blocked items on all lists. I do that as a matter of course for any implementation.
Val Gameiro
Senior NAV Analyst
BPL Plasma Inc.
Austin, Texas
NAVUG Austin Chapter Leader
5.  RE: Eliminating blocked items from purchase quotes item selection
Posted 8 days ago
Edited by Eduardo Diaz 8 days ago
Add the following filter to exclude the Blocked items from your Requisition Worksheet. Cheers
Eduardo Diaz
Minequip Corp.
Miami FL
6.  RE: Eliminating blocked items from purchase quotes item selection
Posted yesterday
I do not think this can be done without the Code change. If you like to make the code change, design the Purchase Line table, in the "NO." field table relation, add the table filter for blocked = No.
tis will eliminate all the blocked items from all of you purchase line related pages. Same you can do with the sales line table as well.
Naveen Jain
Director of IT
Symbex Companies
Santa Fe Springs CA
