Canada - Ontario (Toronto)
1.  French Reports
Posted 10-11-2017 01:02 PM
Hello All,
We need to create french versions of a few customer facing reports/documents. How would we go about doing this?
Thank you
Jason McNish
2.  RE: French Reports
Posted 10-12-2017 03:56 PM
You will need the "FRC" language layer added to you NAV License, if you don't already have it. If you are running base NAV reports then you may already have the "FRC" captions on the fields.
If you have custom or modified reports, you will need to create "FRC" language captions for fields in the report(s).
Finally, you may want have "FRC" descriptions ,for items, then these will need to be setup.
You then will need to set the language code on the Customer Card.
Andrew Good
Toronto, ON
