NAV Programming newbie - flow fields in SQL views
  • 1.  NAV Programming newbie - flow fields in SQL views
    Posted Aug 09, 2018 01:31 PM
    I need to add the assembly BOM field from the Item card in a view.  This is a flow field.   I have a view that is pulling the fields from the BOM component table in NAV .  And I have a separate view that is pulling the fields from the item table (27).  The Assembly BOM field as a flow field on the item card is a Boolean type.  What will be the SQL statement that I need to add the Assembly BOM field to my Item view so that the Assembly BOM field will show up as "yes" or "no"?
    Debbie
    Debbie Danner Greene
    Senior Analyst
    Samaritan's Purse
    Boone NC
  • 2.  RE: NAV Programming newbie - flow fields in SQL views
    Posted Aug 10, 2018 03:41 AM
    If it's pulling in to SQL from the table as a '1' or '0' then a CASE When Statement should work
    Raul Martinez
    National Raisin Company
    Fowler CA
  • 3.  RE: NAV Programming newbie - flow fields in SQL views
    Posted Aug 10, 2018 05:54 AM
    Hi Debbie,
    I did a Webinar on this topic for NAV Skills here:
    C/SIDE Development 101 #5 - Field - keys, SIFT and more
    YouTube remove preview
    In this session David Singleton explains Fields, Keys and SIFT for Microsoft Dynamics NAV
    View this on YouTube >
    Also in October I will be covering this in my presentation
    APP84 - Understanding Dynamics NAV on SQL
    Thursday, October 18
    8:30 AM - 9:30 AM
    I hope to see you there.
    David Singleton
    Go Live International
    SQL Perform Navision Performance Consultant
    dsingleton@go-live.us
