Adding Shortcut Dimension 3 to General Journal Line 81
  • 1.  Adding Shortcut Dimension 3 to General Journal Line 81
    Posted 9 days ago
    I am in the trying to implement a new company on Business Central.  I am using Config. Package to upload historical financials.   How do I get shortcut dimension 3 as a field in the excel export?   All that I have been able to add was Dimensions 1 and 2.
    Kyle Rudolf
    Peter Cremer North America
    Cincinnati OH
  • 2.  RE: Adding Shortcut Dimension 3 to General Journal Line 81
    Posted 9 days ago
    first check out the name of shortcut dim 3 in your setup, could be eg. area code. then check with inclient designer if it is in the field list.
    additional follow https://community.dynamics.com/business/f/758/t/240273
    Franz Kalchmair
    Microsoft MVP
    Senior Consultant
    Austria, Europe
  • 3.  RE: Adding Shortcut Dimension 3 to General Journal Line 81
    Posted 9 days ago
    There was a long thread on this topic within the last month. Check the archive for a quick answer.
    Ron Ketterling
    Minneapolis MN
  • 4.  RE: Adding Shortcut Dimension 3 to General Journal Line 81
    Posted 7 days ago
    Hi Kyle,
    Have you tried using the Configuration Worksheet -- it has the "Dimensions as Columns" boolean, shown below:
    Ramin Marghi , CPA, CGA
    CPA, CGA | ERP Consultant
    Catapult
    VANCOUVER BC
