1.  Import a company from other database
Posted 06-16-2017 07:32 AM
Versions: NAV 2016
We have two databases of same version 2016. One is main one which is bespoked. Other one is standard obviously data in it and has few companies. I would like to have those companies from standard one get imported to the main one as additional companies. So lets say main database has companies 1,2 and 3. The standard one has company A. The end result should be 1,2,3 and A in the main database.
How would you achieve that?
Thanks.
I K
Dynamics Nav Developer
2.  RE: Import a company from other database
Posted 06-16-2017 03:00 PM
Copying companies is simple in NAV 2016+
Use the NAV powershell.
Export-NAVData -DatabaseServer 'Servername' -DatabaseName 'DatabaseName' -CompanyName 'Company' -FilePath X:\path\to\file\filename.navdata
Import-NAVData -DatbaseServer 'Servername' -DatabaseName 'OtherDatabaseName' -CompanyName 'Company' -FilePath X:\path\to\file\filename.navdata
Export-NAVData on MSDN
Import-NAVData on MSDN
Ian Ray
Cypress Grove
Arcata CA
3.  RE: Import a company from other database
Posted 06-16-2017 03:21 PM
Thanks Ian
Is using powershell method any different from using the import/export companies from RTC? I have tried the RTC one , exported the data to navdata and on importing it throws an error as table definitions are different.
Does the powershell method also export all ledges and import to other database?
Please advise.
I K
4.  RE: Import a company from other database
Posted 06-16-2017 03:55 PM
The cmdlets and the import/export from the RTC are the same as far as I know.
If the databases are that different, you could try creating a third one and "upgrading" it to be like target with the development environment before exporting.
There is also this tool, but I have never tried it
https://mibuso.com/downloads/copy-nav-2013-r2-company
Ian Ray
Cypress Grove
Arcata CA
