Same item, different packaging
  • 1.  Same item, different packaging
    Posted 20 days ago
    Hi Everyone.
    We have the same item bought from different suppliers, the item is the same as is the case qty, but the actual box the item comes in, is a different size from each supplier.  Is there a way to store this info in NAV without setting up different items.
    I have looked at SKU's and variants but neither seem to have the fields needed to do this.
    Any ideas greatly appreciated.
    Many thanks.
    Adam Jones
    Celebration Packaging Ltd
    Burton upon Trent
    United Kingdom
  • 2.  RE: Same item, different packaging
    Posted 18 days ago
    Hi Adam,
    Have you considered using a Unit of Measure to represent the two different packages?  They can both be setup as 12 each = Case (or ever how many) but one can say 'XCASE' and the other 'YCASE' to indicate which one needs to be used with which Vendor. The Unit of Measure table also contains the physical measurements to associate with the two different sizes.
    Crystal Tollison
    Onalaska WI
  • 3.  RE: Same item, different packaging
    Posted 18 days ago
    Following because this also happens to us sometimes. I do like Crystal's suggestion of using the UoM. Keep in mind Adam though that then any data pulled such as for sales history or inventory forecasting will have to combine both UoMs.
    Jessie Myszka
    Co-Operations Director, Equal Exchange
    Portland OR
  • 4.  RE: Same item, different packaging
    Posted 15 days ago
    Hi Crystal
    Thank you for your idea, I'll take a look into it, certainly seems more promising than what I'd looked at so far.
    Many thanks :)
    Adam Jones
    Celebration Paper & Plastics Ltd
    Burton upon Trent
    United Kingdom
