"Invalid object name '[NAVDBName].dbo.[CompanyName]_$[TableName]$VSIFT$[Number]'. Statement(s) could not be prepared"
  • 1.  "Invalid object name '[NAVDBName].dbo.[CompanyName]_$[TableName]$VSIFT$[Number]'. Statement(s) could not be prepared"
    Posted 5 days ago
    "Invalid object name '[NAVDBName].dbo.[CompanyName]_$[TableName]$VSIFT$[Number]'. Statement(s) could not be prepared" error message when you run the SETAUTOCALCFIELDS function to calculate flowfields in Microsoft Dynamics NAV 2017
    In SQL server 2014, everything is ok.
    In Designer I can compile everything.
    Henrik Jensen
    IT Chief
    Ocean Prawns A/S
  • 2.  RE: "Invalid object name '[NAVDBName].dbo.[CompanyName]_$[TableName]$VSIFT$[Number]'. Statement(s) could not be prepared"
    Posted 18 hours ago
    Henrik,
          Have you examined the keys in the table design to make sure they are enabled? Try turning on the debugger to get to the exact line of code it is failing on. If you have no modifications in that area, check the cumulative updates to see if this bug has been reported and fixed.
    Joseph Flynn
    Sr. Dynamics NAV Developer
    Gold Star Foods INC
    Ontario CA
